Leaking 40ml waste bath outlet to stack
26 Jan 2008
Northamptonshire
I have fed the new 40mm waste pipe into the original bath waste stack outlet.
the trap is connected to the bath and any amount of water will not leak and drains away from the bath.
However just as the bath empties, the waste drips from the stack opening.
I think the seal in the stack opening has expanded and it will not seal around the new waste pipe.
Can I get new seals for this at all?
Thanks Ian
Depends on type of connection to stack, may be able to fit a new boss adaptor, but if you have a different type I doubt you'll get a new seal that'll fit and stay watertight. Photo of offending article would help to advise on possible solutions.
