hello i would like some advice a flat roof that is leaking where plywood under rubber covering . The plywood goes in under the main dwelling it has rotted away and their is a drip when it rains the damaged plywood is about 10"
Would be OK to replace the damage part of plywood and should the rubber go as far under the main dwelling as possible to protect the plywood or should the slates protect the plywood thanks tecman
