Your typing is not too bad now you need to learn to read, go to the top, start clicking and reading,learn to help your self its that easy, did your first post not tell you anything
Cleaning limescale deposits from inside tap mechanism
Applying grease to thread of tap mechanism
Check condition of seating inside tap - the bit the washer presses against to stop the water getting out - you can buy re-seating kits, although I've never needed one yet
or replace the tap even!
I've changed tap washers and it's made little or no improvement until I then did the other things on the list!
I thought it was a wind up, or someone taking the p*ss, god help him !!!
you never told him which way to turn the spanner/ screwdriver he will be back in a bit after he has scrached his head a bit
