Just moved house. Kept having to bleed rads, then heating engineer noticed pressure was low on boiler (pressurised system provides heating only). He adjusted pressure to correct level. Later on I found a streaming leak in ceiling void! Emergency plumber stripped back plasterboard to find Hunter Genova pipework leaking at a junction. He freaked out because he'd never seen this system before. Having done some research myself I understand it was discontinued about 10 years ago. It also seems to be quite disliked, repair sounds experimental and it's brittle.
Not sure what best move is from here. All visible pipework is copper, so I assume this plastic stuff is all pipework thats hidden in voids/boxing. I'm fearful of a repair going wrong and us being without heating, and a big bill, so wondered if this Fernox leak sealant would get us by until Spring/Summer when I think it'll be best to strip it out and replace with copper or perhaps pick a new greener heating solution since the boilers old too.
I'd love to be able to fix the 1m square gapping hole in our dining room, but fear after leak sealant we'll have the same problem again without warning.
Nightmare! Please discuss.
