I have a 16yr old Megaflow Indirect Cylinder 170litres. Water is heated from a gas boiler. The tank is leaking slightly and it appears to be coming from the side electic element connection, although as it is sealed with insulation it is difficult to tell. The tank air bubble disappears after about a month or so no matter how much I drain from the tank - I usually drain to just below the release valve. It appears that when the bubble dissappears the tank will start to leak. The pressure relief valve does not expel water. Cold water pressure is 3 bar. Is it worth repairing, or should I replace the cylinder.
