A part under my sink replaced as it came apparat. It got replaced by a new part and it has now stopped leaking. Along the bottom pipe not the bit that was leaking there is a dripping sound like a leak but it's not wet but the pipe runs out under foam bits under the bath. The drains are a tad blocked up so I was going use some drain cleaner anyway. Could the sound be inside the pipe or is that not possible?
It doesn't do it all the time though someone on another forum said another pipe could have came lose? The bath panel is joined into the toilet and has foam underneath so there's little space to see.
