Can't find a specific answer to this so wondered what my options are...
[I have a sealed system with a baxi ecotech combi boiler ]
I've taken off two radiators in my front room whilst decorating and then noticed I had a small leak at the lockshield valve where the copper pipe attaches to the valve.
I tightened it a half turn and it was still leaking so I tightened it a bit more and the leak got quite a bit worse! At this point I panicked and isolated all radiators in the house.
This seems to have (eventally) stopped the leak as the pressure in the boiler dropped and it shut off. This was late last night so i went to bed with a plan to look at it after work tonight. Think these are the right questions to be asking....
1. Do I now drain the remaininig water out of the pipes (leaving the rest of the water in the isolated radiators)
2. What do i do with my boiler? Do i switch it off or just leave it with the low pressure error code and re-fill system later? Do i need to switch off any water supply anywhere?
3. Do I now just remove lockshield valve and replace the olive? What happens if (microbore 8mm or 10mm) pipe is deformed?
4. How do I correctly refill system not getting an airlock and add new inhibitor to it?
Sorry for the essay - just wanted to give as much info as possible.
Rich
Rich
