Leaking PVC pipe coupling
8 May 2014
London
Hi all
Just wondering if I could get some advice on a little issue I am having.
I discovered a pretty heavy leak coming from a pipe that leads from my cistern to the toilet pan. The pipe is PVC and has two fittings, one directly on the cistern and a joint slightly below. After doing a little troubleshooting, I can see the leak was from the lower joint. I tightened it as much as I could which has drastically improved the leak, but there is still a tiny bit of water coming out, like maybe one drip every hour.
Is it a case of tightening it even more or do I need some teflon tape or could the joint be broken altogether. I tried to do some googling on this type of joint but I cant find anything. I dont know its name or if it contains washers\seals of some kind.
Anyway, Ive attached a photo. Thanks in advance for any advice, even if its just the correct name for the joint
You need a new washer for the bit that leaks. Unscrew the bottom nut and pull the flush pipe carefully down, out of the connection. Remove the knackered conical shaped rubber washer and get a new one the correct size from b&q or a plumbers merchant.
It shouldn't pour water all over the place while you do this but, just in case, do it with the cistern empty. Either turn off the water supplying it, or tie up the ball float with a bit of string.
And make sure nobody flushes it when the pipes out :wink: you'd be surprised.
Ahh ok, so it does contain a washer. Thanks for that, seems easy enough.
LOL about the flushing, something my missus would do.
Thanks again!
