Just discovered that a HW pipe that is supplying the basin in my under stairs closet appears to be leaking at a copper right angle joint (occasional drip). Anyway first question:- I am just about to go away for a while and I was wondering if there is a product I could buy from B&W that could be applied around the joint to prevent the leak?
I know the best way is to take the joint off and replace it. If I do go down this route I would stop the water supply; drain the pipework; remove the old joint with heat and finally clean up the pipe ends with some emery cloth. Question:- can I use the same pipe ends and simply put on another joint & solder or do I have to cut them clean with a pipe cutter (could get tricky)
