came home from a trip to find the radiator leaking where the pipe goes into the valve that controls the flow (the one with all the numbers on it.
Where the hell do I find the stop to shut off the water supply to the system? Where is it likely to be, by the tank, the attic? Is it likely to be hot or cold? Nothing seems to do it, nothing is labeled.
Or can I just freeze the pipe long enough to undo the nut and put in a new washer / olive thing?
