Leaking radiator valve - downstairs living room
6 Jan 2021
My heating was working fine, but I've recently discovered a leaking radiator valve in a downstairs radiator.
It's a very slow drip. So far, I've just turned the heating off and screwed the top square part of the radiator all the way down. I've also screwed down the valve on the other side as well.
What's the best way to fix a slow leak? Do I need to drain the whole system?
Thanks in advance
Has your action stopped the drip? Depends on system, pressurised or gravity, but both doable without draining down but try above advice 1st
