I have recently moved in to a house with a new Combi boiler / central heating system fitted. I don\\\'t have much experience of combi boilers - my last property was all electric.
1. When I moved in boiler / radiators were working fine - no leaks etc. - but I did notice the radiators were making a noise and decided to vent them which released some air in the system.
2. Next morning there was no CH or HW and the boiler would not start. The pressure had dropped to 0 bar. My neighbour (plumber) refilled with the flow / loop pipe and brought the pressure back up to about 3 bar. Two of the radiators began to leak at the valves so he tightened them up. I put kitchen roll down to monitor further leaks.
3. When I arrived home in the evening the radiators had leaked more. I also noticed a puddle under the boiler and that the pressure had dropped to about 1 - 1.5 bar. As the pressure had dropped I decided to bring it back up to 3 bar again by refilling with the flow / loop pipe. I then went back and tightened up the radiator valves further.
4. This morning I noticed that two of the radiators still have a leak. However the boiler pressure seems to be just above 3 bar.
What pressure should the boiler be at?
If you bring it up to say 3 bar, should it reduce and level off at say 1.5 bar?
Would there be anything wrong with the valves / joints in my radiators or is it just that the pressure is set too high (i.e. will they leak slightly until the boiler reaches a comfortable pressure?
Thanks in advance.
Thanks in advance.
