Leaking shower head - 12months old
29 Jul 2007
Lancashire
Hi
When I get a shower water is gushing from what appears to be between the pipe and the shower head. It doesn't leak when turned off.
The shower is 12months old (new property so I don't know the make, the builders are less than helpful :cry: ). Tthe shower door is Mira but the shower head doesn't say Mira. The washers don't appear damaged. Any ideas?
I recon your pipes pulled off inside the metal hose casing, just unscrew it from the shower head and check, you may be able to reattatch it or at worse buy a new hose.
