On the back of my toilet is a straight push fit soil pipe connector to the waste pipe in the wall. It started to drip water at the joint between the toilet bowl and the connector.
I've pushed the connector off and back on again and also I've rotated to connector thru 180 degrees by spinning it around in situ, but it still drips.
I guess that I could fix it by replacing it, but that would mean removing the toilet, a big job for me! Is there a sealant that I could use to try to make this joint watertight, such as shower silicone seal?
The house is 9 years old, so I guess that this is the age of the toilet and all its fittings too.
