I have a Ariston euroCombi system which for some unknown reason depressurises to below 0.5 bar when the system is switched off. The boiler will run fine all day, I have even had it running constantly for 3 days with no cutting out. But as soon as the system switches off, the pressure drops and the system will not start.
Water is leaking from the pressure release valve (about half pint to a pint). In order to get the system to come on again you need to fill from the loop, but it only requires a very short burst from the mains to get it going again probably around a half pint. Once the system gets started again, the pressure goes up to around 2.5 to 3 bar and stays there until the system goes off again. Then it is back to having to fill it again!
I have replaced the pressure relief valve thinking the membrane could have been compromised. But either I have bum luck with the PRVs or the probelm is something else. Any ideas?
