leaking toilet, seating not sitting flush
9 Jul 2008
New South Wales
Ok my toilet is leaking and have already replaced the seating washer, yet it still continues to leaking.
At times when i flush their is no water leaking but other times it will leak and i found myself having to take off the lid and carefully repositioning it the seating valve, which then stops the leak.
please help!
This the type of flusher:
Difficult to see from that picture (but well done for providing one :wink: ), but the rubber sealing washer looks to be shy of the edges to me. I'd suggest a washer of the same internal diameter but slightly larger external diameter. Can you tell us where you got the system/valve from?
Not familiar with this model but when you flush does the grey pipe lift up?Is the black part to the left a float to push the flusher back into place as it fills with water, if so maybe it just all wants adjusting .
It is a Caroma flush system, that has always been in the toilet.
the washer is put on the grey pipe, when i flush the pipe lifts up along with the washer and then drops back down
