Help! Have just installed new back to wall pan (Roca) . There seems to be
a small leak coming from pan connector . The outlet on the pan appears to be a lot shorter than most and you cant push the pan connector on far enough . Has any one else come across this before ? I have tried using different pan connectors but the rubber seal does not fit far enough onto the pan outlet .
