Leaking Valve
24 Dec 2006
Lancashire
Hi people,
I've come here as we are currently decorating our home and in the process we have taken off an old radiator in the living room. Since this, the valve is leaking slightly (just a drip-a-second). We have a combi boiler and I was wondering what to do. I have tried tightening the valve (whilst I did this I put equal pressure in the opposite direction to keep the valve steady) and this has done nothing. If anything, it has sped up the leak! :(
Now I have closed the in and out flow of the boiler heating system and i'm wondering what to do next. I'm not sure how I would go about draining the system as the radioators in my house have got ****e bleed valves so i wouldnt be able to bleed 50% of them? (if needed?) plus im confused as to how draining the system would work as the radiator is downstairs and the pipes are fed from the ceiling?
We have a new radiator and new valves but can't get hold of any plumber to save our lives and we need this fixed ASAP!! i will upload some images soon for you to check out of the valve and our system.
Any help what-so-ever is greatly appreciated!
If you have not got a suitable drain off under the rad you need to buy a 15mm self-cutting washing machine tap and fix it onto the lowest pipe to the rad. You can then drain down in a controlled fashion.
When drained change valves and then fit drain off in place of wm tap.
ohhh be careful
I badly hurt a boiler with one of them, the disc left by the self cutter found its way into ther DHW HE and blocked it so I would avoid them
best to turn off the rad by the valves, drain the rad and then use one of the rad valves with a hose pipe connection
just dont foget to whack a Drain off in
