Leaking water inlet mffi27
19 May 2015
Hi.
I have an Ariston Microgenus mffi27 boiler. The washer on the cold water inlet appears to have gone and the connection is leaking. I've looked at the installation and service manuals, and it appears that the washer fits between a flat surface on the inlet valve and the boiler ( diagram on page 7 of the installation manual), rather than being recessed like a tap connector. Is it possible to change the washer without removing the boiler from the wall?
Thanks in advance...Phredd.
cant see the manual but they are usually 1/2 inch fibre washers,sometimes called 1/2 inch gaskets,available from toolstation etc.Boiler stays on the wall.:cool:
Great, thanks.
Got lots of washers as I do quite a few minor
plumbing jobs, but if the boiler had to move its a gas safe man job.
