Hi guys,
I need a little plumbing advice...
I noticed last night that I had a pool of water below underneath our combi boiler, I took the cover off but could not see any where the water had leaked from. I did notice however that the plastic ledge just below what I think is a pump was wet, but the pump felt completely dry.
So, I put a bowl below where I though the water was leaking from and checked it just before I went to bed and the bowl was empty. So then I checked it a little later in the morning (after the shower had been used) and there was about 1/2" of water in the bowl.
So again , I checked to try to find where the water was leaking from but there were no visible signs except for there being a little pool of water on the plastic ledge just below the pump.
Is there anywhere else that water can leak from in the boiler apart from the pump? Also is there anything I can do short of calling out a plumber to try to fix the problem?
Damage
Damage
