Led driver question.
  • Thread starter Thread starter Alltheones
  • Start date Start date
A
Alltheones
Hi electrician here but been out of the country a while so not 100% on current regs here just a quick question, I’m fitting some led coving and wondering if there’s any reason I can’t put the driver in the wall behind the switch, it’s a stud wall but it’s packed with insulation but it would go in and would be accessible when removing backbox, can’t really get it anywhere else in the room, and as I see it it’s just the same as one jammed in a loft under insulation. only other option is inside bathroom vanity or under the floor the latter been a nightmare to get to when it goes
Ye will be behind a dry line back box so yes if I were to need to I could take off the light switch and take out the box and I could pull it out.
