Needing some help here:
We've got a set of 3 halogen spotlights on landing in our house, with a switch at the top and bottom of the stairs.
The fittings are (according to the label on them) able to handle up to 20W halogen (MR11 type) and they currently have 14W halogens in each.
We have tried to replace these halogens with 3W MR11 GU4.0 LED bulbs to save on electricity usage but now all they do when turned on is flash once and then go dark.
They don't flicker, or stay on at all; they just flash once than that is it, almost as if they have shorted out or tripped a fuse. All the fuses and circuit breakers are unchanged when this happens.
We've tried 2 different types of LED bulbs in these fittings and get the same response from either type.
I've tried using a mixture of LED and old Halogen bulbs but again the same. And I've even tried only fitting a single LED or leaving one fitting empty, again the exact same thing happens.
We've got larger 3.5W MR16 bulbs in other fittings in the house, all of which work perfectly.
We're at a total loss as to what the problem is, any ideas?
