LED strip light
M
marsaday
Any idea what light i should use as a feature for our chimney breast.
It is in the attic and it forms a semi circle. So on both sloping sides i want to place an led light which is connected and goes all the way to the floor.
On both sides i have a mains voltage feed for these lights.
Any links would be good.
yes one flue is still used, but it is all sealed up and is pretty robust. cant see any heat being generated on the outside brick work.
View media item 36923
those flexible strips lookl exactly what i need.
Will they need a transformer as well or is that included?
Before you start diving in choosing and installing electrical items you should perhaps check back on what you told the council would be the way you'd comply with P1.
the sparky is doing that and all is fine so far.
Also i dont need to tell the council anything.
