Is there a minimum length of the 'hot' pipe which comes from the top of the cylinder?
I read somewhere that there WAS a minimum length before connecting it to anything like plastic pipe//fittings but I'm not going to be doing that.
Reason is, as I have said in another thread, I am looking at moving the cylinder.
The current setup has a fairly long length of pipe from the top of the cylinder - horizontally. If it was kept at the same length after moving then it would mean I would have to look again as to where to site it as the extra width would cause an issue.
If there IS a minimum, what is it please? If not, how soon after the connection to the top of the cylinder can you make a bend and is there anything to stop it going down vertically?
Yeah, I know - more stupid questions from eejits but the whole point of this is that, before I get the qualified plumber in to move the whole shebang, I want to be able to tell him [or her!!] exactly what I want.
I've read enough and know enough tradespersons to know that you should know EXACTLY what you want instead of chopping and changing your mind.
If I know the answer to this one then I will be able to tell the plumber precisely where I want the cylinder instead of him [or her!] arriving and telling me I can't put it there.
Make sense?
Probably not so apologies in advance.
Make sense?
