Hi All,
I'm renovating a bathroom and putting in a corner shower.
I pulled the old tiles off and it's left the backing plaster in a bit of a mess. The wall where the shower will go is also not very straight. Laying a straight edge across shows it bends by about 15mm horizontally.
What's the best way of leveling this out so it's level with the rest of the wall?
I don't think I can chip out all of the remaining plaster, as it's applied onto concrete blocks and doesn't come off very easily at all. But I could probably take the overall level down by about 10mm.
Following some advice on another forum, I think I'll be using sand and cement render. So my plan is to chip out as much of the plaster as possible in the shower area (to the left of that vertical channel revealing the concrete blocks that you see in the pic), then put a batten in the corner which is level with the remaining wall which is to the right of that vertical channel. Then sand and cement render between the wall and corner batten to bring the whole thing level.
Does this sound like a good plan or overkill or is there a better way to do things?
Please see the attached pics to get a better idea of what's going on.
Cheers, Rich
View media item 27463 View media item 27465 View media item 27464 View media item 27466
Cheers, Rich
