I have a basement room where the floor falls from a high spot at the door to -45mm on the far wall, the floor covering is bitumen. I was planning on using a cement screed but have since read that this should be used at a minimum thickness of 50mm so no good for this application. What would be the best method of leveling this floor, should i be using bitumen? Any advice appreciated.
Rob
Rob
