Hi everybody,
I have read the very informative stickied post by mattysupra about leveling an uneven wooden subfloor. Things that make it tricky for me are people describing it acting almost like water. I have had issues before with leaks, water trickling down the joints of the chipboard (or in the old nailholes in the original chipboard) in my subfloor and damaging my neighbour belows ceiling. I absolutely want to avoid this happening again. The stickied guide advises using caulk to plug but I am just not 100% that it would be possible to plug every little route down below.
I had half the subfloor ripped out and replaced a while ago but it has not been made level with what was there previously. I had the idea to put down thin ply at the worst bits (5mm or more) and sheet ply over the top of all this although this seems like a far from ideal solution. I should say that I intend to put down vinyl click board flooring after this. The whole area is 1750mm x 1350mm.
Is what I have started doing going to be nowhere near adequate enough?
Should I definitely be looking at a self leveling compound and if so how can I make absolutely sure of it not dripping below?
Is it better to have the toilet not resting on the click flooring and simply silicone sealed round, or to take it out, install the flooring and place it back in above the vinyl?
http://ceiling2floor.co.uk/product/wpc-vinyl-click-woodplank-white-oak/ is the product I was looking at.
Other smaller queries I have are:
What is the best way to remove the toilet without leaking water to enable me to work on the floor?
The information I can see from vinyl click boards all describe it as waterproof. Does this mean it absolutely will not have water penetrate it or just that it won't be damaged by water? I am very cautious about ever having water damage issues again, especially in unseen places like that.
Thanks for reading and I look forward to seeing what you guys think.
