Lever for filling loop
18 Oct 2012
Hi all,
Can anyone please tell me what's the technical name for the valve lever that fits my picture (part of my boiler's filling loop) and where can I get it?
Thanks!
:mrgreen:
View media item 51521
Plastic turn lever :P
Often these are the same as fitted to washing machine valves but in the meantime you can get by using an adjustable spanner on the valve flats.
I'm sure any plumbing supplies place would help you out with that one, but of course the centre screw will be missing so you may need the complete valve to get what you want.
John :)
I'm not sure that's a dedicated filling loop. It looks like a washing machine tap fitted into a 15 x 3/4" flexi. Is there a double check valve on t'other end?
It is a dedicated filling loop as I already used the valve to top up my system several times (see additional picture showing the double check valve). I know I can just use an adjustable spanner but just wanted to put the turn lever so that I can top it up without any tools.
View media item 51535
if you have to top it up that much you have a bigger prob than trying to find a plastic lever
