Hi all,
I have a central heating issue - which as soon as I start looking into it I can't replicate the problem - isn't that always the way, anyway.
I have a standard old style central heating system, open vented, rads and hot water cylinder - coupled up with a 3 port valve. (ACL Drayton Lifestyle 679H340-30L0)
The problem is I think the motor in the 3 port isn't completely moving over or the micro switches are getting a bit dodgy, as at various times the timer and room stat are calling for heat, the boiler is ready but not fired up, and the pump isn't pumping.
At first I thought it was the pump jamming as with a few 'subtle taps' it all fired up and worked again. However I'm thinking it is actually the 3 port valve - which is right next to the pump so the taps could well have just transmitted to the 3 port.
The problem I have is that whoever put the system in put the 3 port valve horizontally with the head part right up tight against the hot water cylinder - so I can't get the head off (I can't even get the cover off). However, I think with a minor bit of pipework I can rotate the valve through 90 degrees to make it stand vertically.
Is there any reason that the valve has to be on its side? and moving it to vertical is going to cause more issues?
Also if I'm going to the bother of draining down etc is it worth changing the entire valve itself? (and maybe even the pump for onbe of these new more efficient ones from grundfos...) they must be well over 10 years old - as I've been here 10 years and I doubt they were even brand new when we moved in... how long would you expect pumps/valves to last?
Cheers
Steve
Cheers
Steve
