Long story short - I live in a flat. Suspected leaking water pipe under floor although floor itself is dry.
The plumber has said that to get to where the leak is properly, he would have to lift up the carpet, the PU foam underlay and cut through the wooden floor to the concrete underneath. He's said that unfortunately he would not be able to preserve the wooden floor. I have a little over a week until he comes back to find a better option.
Even though I'm supposed to keep the property carpeted, I would like to preserve the wooden floor if I can (as I'd like to keep the option of removing the carpet at some point) as it appears to be good quality engineered wood. I'm toying with the idea of lifting up the floorboards temporarily.
I've read through the various threads about tongue and groove and I can see it's not always possible without damaging the flooring. I've tried lifting up the floor edge (the pic with the carpet lifted up) with my fingers and it seems pretty solid (although the carpet door plate is nailed in) so I suspect it's possibly been glued.
Because there's a possibility it's been glued, I'm not 100% certain as to what my options for minimal cosmetic damage would be...
What are your thoughts? Thanks!
