Light fitting 4 cores to light unit
Can we assume there is only the one light that is operated by the switch for this light, there is not another light fitting that comes on when the switch is on?
^^ cheers. Yes, only one light switch that switches this light on and off.
Will re-wire as advised tomorrow night and let you know how I get on.
thanks all
Once you have reconfigured the wiring back to it's operational state, it would be appreciated if you do give us feed back and confirm our thinking was correct, please be aware that without physically being there, we are making assumption on what you have presented as evidence and normally we would confirm the operational state of the circuit via test procedures.
Anyway you know where the button is? or you could send a donation to "The Keep Prentice in Guinness fund" :wink:
Please not that the terminal blocks should not be pushed up into the ceiling void unless they are enclosed in an insulated enclosure (which should remain accessible) Simple binding/wrapping in electricians tape is not suitable as this is not consider good practice or a good insulator!
Use a choc box if required and forget wrapping the terminals blocks!
Ok.
Turn the power off. And take down the light fitting.
Connect all the reds together in a connector block, and tape up with insulation tape.
Get the black wire with the red sleeve. Connect this to the L of the light fitting (brown).
Connect all the remaining blacks to the N of the light (blue).
Connect all the earths (green and yellow) to the E of the light fitting (green and yellow).
Again, best tape up the connector blocks, since all sorts of dust and rubbish can emerge from old ceilings.
Reconnected it all back up as above and works perfectly.
Many thanks to all for your helpful advice! Thanks button used
Thanks for the feedback on a successful sort out, thanks much appreciated, I suppose the Guinness fund will have to wait until next time!
Anyway are sure it was not my instruction you followed?
Wrapping terminal blocks in bloody electrical tape :roll:
Seal the hole to prevent dust and if poking them back in void use a choc box and leave accessible.
I meant wrapping the terminal blocks in tape with the connections between the ceiling and the light fitting. I never suggested putting the connections in the ceiling void.
Is it a major no no to add some insulation tape within an enclosure to connector blocks supplied with the light fitting?
It's a pain in the arse when you are trying do some testing on the conductors and identifying core colours. If the termination are made correctly and the enclosures are suitable, then there would be no need for it!
But that is based on my experience and my bias opinion, which does not necessarily mean I am correct but I don't think am I wrong :wink:
