I want to replace an existing upstairs pendant light fitting and also move the location of the light by approx 2 metres.
The existing fitting has a standard ceiling rose with the "loop in" connections, and as I am relocating the fitting, this will need to be replaced with a junction box in the loft.
The new fitting fits flush to the ceiling with just the LNE cable which I assume I will "chocolate box" connect to the extended cable.
Some Questions:
1. As the JB will not be accessible, I presume I will need to use a maintenance free type of JB, is this correct and is a "WAGOBOX" an appropriate type?
2. Would this work come under Part P and be notifiable? I was thinking it wouldn't as I am only replacing an existing JB (Ceiling Rose) with another (albeit slight different type) and not changing the number of circuits. But I stand to be corrected on this![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
PS - the light fitting is for the upstairs landing so not in a special area such as bathroom/kitchen etc.
Thanks, Mark
Some Questions:
Thanks, Mark
