light fittings - earth required or not
10 Aug 2005
Oxfordshire
I bought a ceiling lamp, made from cut sheet metal, an moroccan design without any wiring or light fitting. Is a cable with earth required or would a 2 core cable be sufficient? Are there any rules which govern whether lamps require an earth, and come to that why do some appliances need an earth and some not?
__________________
moderator
moved as posted in appliances
If it has no lamp holder or wiring, just what is it that makes it a light fitting?
It won't be CE marked, will it? If common sense doesn't tell you that DIY electrical appliances made out of cut sheet metal are a bad idea, check the small print of your house insurance.
By the way, I earth everything! Especially where metal is concerned!
I am "The Earther"
That can be dangerous if what you are earthing is not meant to be earthed.
Earthing items which are not exposed-conductive-parts and bonding items which are not extraneous-conductive-parts makes things worse, not better.
slippyr4 said:
That implies that you earth plastic.
Hell why not!
Seriously, I dont have any plastic back-boxes. However if I did, I would still continue and connect the earth wire. Why not and dont tell me because its not needed.
Is this a problem?
Bazdaa
Bazdaa said:
Hell why not!
Is this a problem?
Bazdaa
You should indeed terminate the CPC in a plastic back box. That's not "earthing" a back box though. What would you do with a plastic pipe?
No - maintaining cpc continuity by using the earth terminal in plastic boxes is the right thing to do (and does not earth the box).
But earthing items which are not exposed-conductive-parts and bonding items which are not extraneous-conductive-parts is not the right thing to do
Like what, the only thing that I earth are terminals as in light fittings and sockets, and dont forget bonding.
Yes I know what I said, but this has gone a bit further now.
Bazdaa
don't worry about it, i think Bazdaa argues for the sake of it[/quote]
If you bothered to read the thread, you would see that it has evolved. See there you go again, with your comments.
Why not keep this where it should be.
//www.diynot.com/forums/viewtopic.php?t=38072&highlight=
Bazdaa[/quote]
Thanks Bazdaa, i knew you would argue some point :LOL:[/quote]
And you would come back with some comment.
