I have a light in the kitchen which is one has one of those pull up pull down light fittings. It stopped working on Saturday.
The live and neutral switch wire entering the light switch is showing a voltage of 5/6v when the light switch off and 10v when on. The live and neutral entering the fitting show a 5/6v when off and 10v when on. The is continuity between each end of each wire (the live and neutral) in the light fitting. The terminals for the light bulb in the fitting are showing 5/6v when off and 10v when on. I have tried several bulbs and have tested them in other fittings and they seem to work.
Any ideas would be appreciated.
