Light switch question
2 Jun 2008
Sussex
I recently removed a light switch to allow for a reskim of the walls and have since lost the diagram of how to reconnect. I have the old switch and so can draw some conclusions of how it was done.
Basically, there are two sets of lights controlled from one two gang, one way switch. There is one three core cable running to the switch, one of which is live.
On the back of the old switch there is a bridge cable from Common of one switch to the 1 way terminal of the the other switch. Therefore it seems the other two cables are to be connected to the unused 1 way terminal and the unused common terminal.
Before going ahead and doing this I just wanted to know if there is a reason for doing it this way? It seems to me that the set up is just sharing a live and therefore the bridge cable should run from Common to Common with both non-live cables running to the 1 way terminals.
Any ideas?
Both connection methods would work in the same way though better to take the permanent line conductor into a common and link to the second common terminal.
Thanks. I thought so. I think the original switch is wired as described as the second switch is upside down compared to the first so it allowed for a shorter link cable.
