Light Switch terminals
29 Dec 2007
I know the answer is probably to replace the switch, but, why do the terminal screws keep working loose in the back of my lightswtich switch???
It happened shortly after I moved in, and has happened a few times since. Is it something I'm doing wrong????
The first time it happened the screw had removed itself from the back of the switch completley and fell on to the floor when I took the switch off the wall.
Any thoughts????
Either
[1] you are not tightening tight enough
[2] the copper wire has been softened by being over heated due to the first time it became loose and will no longer enable a tight connection to be made. scorched, melted or discoloured insulation is sign over heating has happened
[3] the switches are poor quality
Try a new switch, cut the end of the wire away ( assuming there is enough spare wire), and tightened the screws
It has been suggested that the 50Hz frequency of our electrical supply can over time encourage screws to loosen off.
This explains why the 17th is so sharp on making sure junction boxes MUST be servicable.
Maybe the switch terminals have been over tightened in the past and no longer provide a firm contact due to screw / thread wear. I'd suggest that you replace the switch with a decent brand item and hopefully that will prevent any future need to work on the item.
is this perhaps in a wall subject to vibration on a regular basis? perhaps from a heavy handed door closer?
Possibly the threads on the terminals are worn or don't match up.
Try a new switch.
When re-stripping ends of wires, 'double over' the copper ends where only one wire enters a terminal.
This will prevent the ends from weakening so much.
