i have recently removed a ceiling rose and the switch cable which were not needed. the task was relatively simple and i connected the two circuit cables to each other with access through the boards in the room above. however, since then, most of the lighting circuit has failed. there are 11 roses in the circuit, 3 of these occur before the one i removed, and the rest occur after. the first 2 still work, but the 3rd and the ones after do not. when i've tested the roses, i've noticed that each of the return switch live cables is always live, whether the switch is on or off. why could this be? also, if it was always live, wouldn't the bulbs always be on? really confused
