Lighting for Lounge
3 May 2005
Hampshire
I am looking at replacing the ceiling light in my lounge with halogen / led downlights. My question is is there a limit on how many lights I can use? I have worked out I will need around 12 to 14 downlights to cover the room adequately. Will I need to uprate the fuse at the consumer unit?
Is there an explanation of the types of switching, ie 2gang 1way etc. I have a lightswitch downstairs that has 3 switches. I switch controls the landing light which also has a switch upstairs. The second controls the ceiling light in the lounge the third controls 2 wall lights in the lounge. Is this a 3gang 2way?
Depends on how much load there already is on it. You're the only one who can add that up....
#-gang: The number of rockers/knobs/buttons/toggles on the switch.
1-way: The switch can only do on/off, and you can't have a 2nd switch somewhere else that also controls the same light.
2-way: You can have 2 switches controlling the same light. Also needed if you have...
..Intermediate switches, which go "between" two 2-way switches and allow N-way switching where N=No. of intermediate switches + 2.
It's a 3-gang 2-way switch, but only one gang is actually wired into a 2-way switch circuit. It's quite possible to use a 2-way switch in a 1-way application.
Hope you don't mind me suggesting this, but I think you should spend a bit of time looking at the For Reference section, and with, e.g. the Which? book (see //www.diynot.com/forums/viewtopic.php?p=75416#75416 ) before embarking on any installation work.....
Living room lighting is a main source of lighting you are trying to achieve.
If so you have mentioned halogen lamps which although not my choice are fine, however LED are in myine and most peoples opinions no good for main lighting but fantastic for feature lighting.
