S
Scrappy042
Hi, small overview before the question i'm afraid...
I am considering installing LED lighting in the garden. I have an RCD plug (indoors) going to double socket on the outside wall (the usual B&Q/Homebase black RCD plug to 2-gang IP65 socket box).
My LEDs are to be automated using the Loxone system. It uses DIN-rail relays, majority are 24v. Quick Loxone overview: Mains power -> 24v PSU -> Relay -> LEDs
Loxone have advised for 'testing', a Twin+Earth plug/cable can be connected directly from wall socket to PSU.
But as it will be permanently installed on shed wall (insulated, more like workshop), I have no way of running an extension from house main consumer unit (landlord won't allow it) i'd like to afford myself some more protection and to cover for future additions such as more garden lighting.
My question is:
As it's all DIN-rail mountable, if I install it in an IP65 rated consumer unit, i'd like to install Isolator, MCB and RCD pre-PSU.
Is it ok to wire the Twin&Earth plug/cable to the isolator -> MCB -> RCD combo in the shed consumer unit from the external plug socket?
I guess it is as it's standard 13amp, 240v outlet with RCD plug at the other end.
This video explains the principle, about 30-seconds in:
Any thoughts welcome.
My question is:
