Hello All
Loooking for some help in my electrics, i think they may have been done wrong from the start.
i had normal hang down lights when i moved in. i have started to change them but have run into some issues, can someone help?
i put a halogen light in the kitchen, this had 2 cables with 3 wires in each, i know one is the feed and one is the switch. I then put a fan light in the sitting room, same wires as before, but cant get lights and fan on at same time??? I wired them up like this
reds to the live in the unit
black - return from switch to the switched live on the unit
neutrals to the neutral on the unit
and earth to earth on the unit
but lights on = no fan
lights work on and off from the switch fine
Then Today i fiited the same fan light to the dining room (open plan) but found 4 wires from the ceiling?
i wired them up like this
reds to the live on the unit
neutrals to neutral on the unit
earths to earth on the units
this one works fine! lights on with the fan!
can i assume this???
that the light in the dining room has 4 sets of 3 because - it spurs off to the kitchen and sitting room? that would give me the 4 wires 1 from the consumer unit, 1 from the switch, 1 to the kitchen and 1 to the sitting room?
does this mean the sitting room has not got enough power to power both light and fan???
