Hi...in my kitchen i have 2 sets of four halogen lamps on bars, so 2 fittings controlled by the same 2 switches. One of these switches is a dimmer and the other just on/off.
The pelmut lights are controlled by an independent switch on each light switch.
The have been installed for 5 years.
When my daughter tried to switch on the bar lights using the on/off. She says she saw a bright flash and they havent worked since. There is a serpeate fuse box for the kitchen and it tripped the light fuse. I switched this back on and te pelmut lights work fine
The mrs says the dimmer hasnt worked for some time.
I had a look at the connections in the ceiling rose and all looks ok. I can access the area above the lights but have yet to check the junction boxes up there. Thought it was unlikely to stop working all of a sudden.
Everything was installed by an electrician orginally.
Any ideas?
Any ideas?
