ligthing feed
21 Apr 2007
Bristol
Hi guys....my question is.....can both Line & Neutral be put into a connector block within a deep lighting switch box ?....would be easier due to short cables giving insufficient length for JB behind....ta for answers...
if you are say your switch wires are too short and you want to extend them so its easier to wire your light switch, then yes you can
Hi....thanks for your answers....I have a two gang / 2 way lighting switch with quite short supply cables - 1.5mm T & E and there is not much room for any JB....the wires are quite short and it would be easier if the supply feed (L & N ) was to be taken into a connector block inside the switch box and then fed to the switches....is this ok ?....thanks to Coljack and Fireman22 for answers....ATB
