Lillies and fuchsias?
18 Apr 2025
Hi
First image is fuchsia bush in front garden. I’d it normal to see dead and developed (somewhat?) flowers on the same branches?
Second image is lilies in back garden border. They only flowered for a few weeks, so guess they must have been Asiatic variety? (Can’t recall what we bought) I haven’t pruned but looks like they’ve been decapitated? Should I cut the dying stems now? Where should I cut etc?
Have you been overwatering them? They dont like it and have issues like this along with yellow leaves if their roots are too wet
Hi
You may have Fuschia mite, it is not a native pest but now widespread in Southern England, arrived maybe ten years ago.
Some people say it was brought in by an illegal import from South America by a noted Fuschia enthusiast on the Isle of Wight, but he denied it.
It is said that there is no amateur control for it, but I have tried various sprays and have a survivor. All the other local fuschias were wiped out.
Apparently a mite is not an insect.
Thanks for the helpful responses. Any idea on the lily situation and where/when to prune?
Hi
You just need to remove the flower head stalks and leave to allow the bulb to build up for next year. By late Autumn it will have shed it's leaves and juse leave the main stalk. Once that has gone dry and brittle, either late winter or early spring just wiggle the stem until it easily comes away from the bulb in your hand. If you need to apply any force you will damage the buld.
Thanks. Re “flower head stalks”. Can you help me identify these in the more detailed image, If you look at the marked circle, it’s like there’s an outer stem, inner stem and then a thin section protruding from the inner stem. Is that what you’re referring to?
Probably have to come back to you again re main stalk, wiggling stem and bulb.
Regards
Thin bit is one of the old flower stamen, it's the part of the flower that had the pollen and sometines seeds are formed. What you call the the inner stem is where the petals of the flower were attached. The outer stem is where the flower bud would have begun it's life and developed into a flower.
Thanks. Can you point out the “flower head stalks” as per your earlier advice?
