Lime constructed house with cavity wall… can you insulate
25 Nov 2022
Hi all, just wondering what people’s thoughts are on cavity wall insulation on a 1910’s built house constructed with lime mortar.
I’ve read a couple of horror stories online about people installing modern cavity wall insulation into a period property which subsequently caused a multitude of damp issues.
I’m looking for a product that will Obviously need to be breathable as I don’t want to cause any damp issues.
I’ve read about sheep wool being good for this however I’ve only seen it sold in a roll form which isn’t suitable to get into the actual cavity.
Jamie
How wide is the cavity?
What is the height of the DPC above external ground and paving level?
Where are you?
DPC is around 1ft from ground level
I’d say the cavity is approx 100mm
we’re in lincolnshire
Are you sure you have a cavity?
Most of the houses I've lived in similar to that age have been solid brick, this opens a few different options for insulation.
There is EPS beads, instead of blown mineral insulation, but have no practical knowledge of these, I'm sure others will comment.
You could have blown mineral wool. A reputable installer will inspect your walls for suitability and your cavities for rubble before agreeing, to save themselves the risk of later remediation
Drill a hole and poke a piece of wire in to check.
If you do it just above DPC you can feel for rubble as well
Thanks JohnD,
What properties does mineral wood have that makes it suitable for the job?
Jamie
Quite a good insulator
Treated to be non-absorbent
Non flammable
Will not rot or support moths or other insects
Will not fall out through a hole in the wall
Hiya,Yes I’m 100% sure it’s not solid brick. A couple of houses on our street are solid brick then some are cavity wall.
Non flammable
And is it breathable?
