- Joined
- 24 Jul 2015
- Messages
- 95
- Reaction score
- 1
- Country
I just had a new bath installed, but some of the waste pipe work had been fitted with about a 20 cm section of pipe going uphill ( about an inch or so) after the trap before it does 90 degree turn into a a downhill run eventually to the soil pipe.
Not really very satisfactory. Do you think I can get away with this? It's going to be a pain to have all the pipework adjusted; not even sure it can be done without serious cost.
If no, I was wondering if I were to change the waste combi overflow, there might be one where it is not so long ?. At the moment I can see quite a lot of spare 'screw' space on the brass body below the banjo which seems unnecessary. Its a Macdee bath waste/combined overflow with plug and looking online it looks like the measurement is about 76mm. Are there any shorter then this ?
ALso I noticed that the overflow does not drain very fast at all? Wasn't sure if the level problem would make it worse or are all overflows really a load of rubish unless you pull the plug out aswell ?
