I moved into a new house at the end of last year which is 5 years old & has a linea 726 boiler installed.
Recently I've noticed that it is making a noise overnight, which is waking me up, but when I've looked at the boiler it doesn't seem to actually have fired up - the noise lasts about a minute and occurs every 45 mins or so.
I'm not sure if this has been happening since I moved in and I've just noticed, or has just started (maybe the frost protection as it's cold out, but I'm led to believe that frost protection would fire up for around 20 mins at a time).
This leads me to thinking it's the DHW preheat function, though I'm not sure.
If it is, I know I can disable this with jumper 6 on the PCB, however I don't know where this is located in the boiler (I can't see it in the installation manual) or if it's easy for a novice to do (thought I'm not untechnical).
Can someone advise if this is the likely problem or not, and if so give me some tips on removing jumper 6.
Thanks.
Thanks.
