Hi
I'm lining an opened up fireplace/inglenook with hardibacker 500. Manufacturer says this can be done using cement tile adhesive and then mechanical fixings. I'm fixing these directly to brick.
I'm a bit unclear on the process. Should i predrill the boards, stick them to the wall, wait for adhesive to go off and then drill through the predrilled holes into the brick?
And what fixings would be best. I want the screw head to finish flush. I can't see the fixing process above working if I need to push plugs through the predrilled boards.
Any advice would be gratefully received.
Keith
Keith
