Linking bulkhead lights?
23 Dec 2002
Glasgow
My back garden has a large wall with sections of fence built into it. There are four parts of wall that I was thinking of putting lights on, like these for instance...
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=13062
Before I order, I am not sure if I could link the four lights from one cable into a switch. Each lamp is 60W. I have looked at wall downlighters but they only come in sets of three! :evil:
you certainly can. you would need to wire them in paralell (red to red black to black in each light.
But two things to mention.
As they are mains lights if you put the cable in the ground it should be at least 30 cm below the surface and have mechanical protection. (1mm t & e cable is fine)
As they are bulkhead fittings the light will go every where (unless that is what you want) why not search for some nice low voltage garden lighting it looks much nicer
try this for advice
Thanks Breezer
I am intending grinding along the cement line and placing the cable in the wall, then re-cementing.
I know what you are saying about the lights, I have been searching for wall downlighters with a chrome semi circle housing but geeting a set of four seems to be a problem. I don't like the sound of the light going everywhere so I have a good search of that site you advised, I never seen wall lighters at the glance just now.
Thanks again
that site only gives advice, you may like
which you can get from here
or you may like
from here
or alternatively other types of low voltage lights.
Don't recoment the remove cement idea, what if you forget and put up a hanging basket and hit the cable.
Very nice of you to do that search on my behalf :D I love the chrome one but is slightly over my intended budget.
I've noted the advice on the cementing, I may have a long think about this before 'diving in feet first'.
Thanks for all your help
