linking sky
13 Mar 2010
London
I tried two feed a sky TV signal from the sky box to a TV in another room.
No need to watch different channels, straight feed all thats needed.
I ran a coax cable from the RF out to the second tv.
The sky box is satellite dish fed only no TV aerial.
I am getting no signal
Could be the coax, will check continuity tomorrow , (Is they a way of checking coax other than continuity)
Does the second TV need to be on a different setting to receive this signal
any pointers would be great
Quick question because it's not clear; you did tune the second TV didn't you?
the tv in the bedroom was the tv in the original room, they are getting a new tv for the living room.
Its made difficult because there is no remote for the tv. tried to tune it via the buttons on the tv, but drove mre insane so came home.
Would it not previously have been connected via Scart lead though?
As LS said, check that TV out is on and then try tuning the TV. Until then we can't really say one way or the other. ;)
As default the Sky output is on channel 68 but that can be software changed. If you use RF2 then the digi eye will allow you to change channels in the other room.
Although we have channel 21 to 68 for analogue TV often the outputs are not spot on so although in theory if you know old TV is set to channel 34 for example you could change sky output to 34 this does not always work.
The sky book does not tell you how to change the output channel it is a hidden menu.
The installer menu can be accessed by pressing 'Services 4 0 1 Select'
Got a Sky+ HD box? The installer menu can be accessed by pressing 'Services 0 0 1 Select':
You can also turn the voltage on here to work the digi-eye. But you have posted in wrong area.
Not sure if it's the same for newer Sky boxes but you used to have to change the RF outlets setting to around 55 if I remember correctly.
thats dependant on your location (local transmiter channels) and is to avoid co channel interference
if the remote to tune the TV is missing then erics is the best idea (tune the sky to the tv channel) if an aerial is not being used then co channel interference should not be an issue
but if you are running in a new cable anyway AV is much preferable than RF, ditch the coax
Many thanks
Still have the same problem
Have switched power on to the RF
TV is on channel 21 I think, can switch to 68 using tv buttons but cant set it so goes back
Sky box is set to 68, but no option to change (two little arrows not there)
cheers, and any ideas
Hi first things first answer the following questions
1 what is the make/model of tv?
2 what sky box is it? (standard, sky HD?)
3 where have you plugged in the coax? (which outlet)
Ps was working in boro today
cheers
Samsung le32r74b0
sky plus
tried both outlets no joy
Hope you had a good day in the Boro
I have had problems accessing menu to change the channel number on sky+ before. Found best method was not to look at TV and just enter number followed by select.
It is so easy to miss a function too. I sat there one day wondering why it did not work and then realised I had entered number but not pressed select at the end.
Many thanks for the great replys, but I still have no signal
Changed the sky RF channel to 21 as that what the tv is on but still no signal
On the TV what should I put as the source
the list is
TV
Ext 1
Ext 2
AV - Blanked out cant choose
S-Video also blanked
Component - blanked but says DHR
HDMI blanked but says PC
PC blanked
DTV
thanks
