Hi there
I want to instal two 1150mm wide windows on a load bearing wall of a detached garage. I have previously inserted door and fireplace lintels but would like advice on this one please.
Load bearing wall is 5.1m long, single skin block with 3 brick pillars.
The wall supports half the load of a 30 degree pitch clay tiled roof, with 13 5x2 rafters (the other half of the roof load is supported by another wall).
I estimate that the load on the wall where I wish to insert windows is:
900 tiles@ 1.08kg 972kg = 9.53Kn
13 5x2 rafters 91kg = 0.89Kn
Total 1063kg = 10.42Kn
Half load 531kg = 5.21 Kn
Load per meter 531kg / 5.1m = 104kg/m
Load per rafter 531kg / 13 = 40.84kg
Questions:
Will the 100x65x1500mm steel reinforced concrete lintels from wickes suffice (they don't provide any data)?
How to prop wall before inserting lintel?:
The wall is only 2.1m high and only one course of blockwork will be between top of window and timber wall plate that supports rafters.
Wondered if I could get away with using four strongboy props inserted directly below wall plate and below rafers?
Many thanks in advance.
Questions:
